Meguiar's All Purpose Cleaner美光D10101
小川子
31
邢台
DETAILER PROFESSIONAL'S CHOICE
ALL PURPOSE CLEANER
  • Ideal for cleaning all interior surfaces
  • Active foaming action lifts dirt
  • Fabric softeners enhance luxurious results
DANGER!CAUSES EYE.SKIN.DIGESTIVE AND RESPIRATORY TRACT BURNS.
Read carefully other cautions on the back panel.
3.79L Net 1gal(128 fl.oz.)
ALL PURPOSE CLEANER
Meguiar's All Purpose Cleaner is ideal for cleaning all interior surfaces.The superior foaming action gently lifts the dirt away while its unique blend of fabric softeners enhance the look and feel of carpet,upholstery,vinyl & even leather.
美光全能清洗剂适用于清洁所有内饰表面。其优越的发泡特性可温和地去除污垢,同时其独特的织物软化剂成分可增强脚垫、坐垫、塑料甚至皮革的视觉效果和触感。
DILUTION: Heavy Strength 4:1
Medium Strength 10:1
稀释比例:高强度 4:1
中等程度 10:1
DIRECTIONS: Test a small,inconspicuous area for colorfastness prior to use.Apply properly diluted product to surface.If necessary,agitate with a soft brush or clean terry cloth towel.Using a fresh towel,absorb the excess product until surface is dry to the touch.For continuous use,mix concentrate and water in a bucket.Using a brush or towel,scoop out foam and clean desired area.
用法说明:使用之前,先在一小块儿不明显的地方进行色牢度测试:取适量的本产品稀释液涂于表面,如果必要的话,可用软刷和干净的毛巾布刷洗擦拭,然后,用一个干净的毛巾,收掉多余的产品,直到表面摸起来干燥。继续使用的话,在一个水桶里将本产品和水混合,使用刷子或者毛巾捞出泡沫清洗特定区域。
PROFESSIONAL TIPS:To quickly clean floor mats,spray properly diluted product over entire mat,agitate heavily soiled areas with a brush,rinse with high pressure stream of water,vacuum excess with a wet/dry vacuum and hang dry.Use a foaming sprayer tip and Meguiar's All Purpose Cleaner to clean hard to reach areas such as door jambs.Rinse thoroughly with water.
FOR COMMERCIAL USE ONLY.CONSULT MADA AND TECHNICAL SHEETS FROM SUPPLIER.
专业技巧:为了快速清洁脚垫,可向整个脚垫喷洒适量本产品稀释液,用刷子刷洗重污区然后用高压水冲洗,最后用干/湿两用吸尘器吸干水分然后晾干。可通过使用喷瓶和美光全能清洗剂清洗例如门柱等难以触及的地方。最后用水彻底冲洗。
DANGER!May cause dizziness,headache or nausea.
CONTAINS:WATER 7732-18-5,SODIUM METASILICATE 6834-92-0,2-BUTOXYETHANOL 111-76-2,MIXED ALKYL SULGATES 68439-57-6.
PRECAUTIONS: Do not get in eyes,on skin or clothing.Avoid breathing of vapors,mists or spray.Use only with adequate ventilation.Do not swallow.Wear eye and face protection.Wear suitable gloves and protective clothing.Close container after each use.KEEP OUT OF REACH OF CHILDREN.
FIRST AID INFORMATION:Eye Contact:Immediately flush eyes with large amouts of water for at least 15 minutes.Get immediate medical attention.Skin Contact:Remove contaminated clothing and shoes.Immediately flush skin with large amounts of water for at least 15 minutes.Get immediate medical attention.Wash contaminated clothing and clean shoes before reuse.Inhalation:Remove person to fresh air.Git immediate medical attention.If Swallowed do not induce vomition.Call physician immediately.
