IPA 高浓度伤漆???
Remove compound and polish residue and inspect your correction results
Isopropyl alcohol has long been used by professional detailers to accurately inspect their correction results after removing swirl marks, water spots and other paint defects. When properly diluted, isopropyl alcohol removes polishing oils and fillers, enabling you to see the true condition of your vehicle’s finish. Isopropyl alcohol also works well for removing caked on compound and polish residue.
Isopropyl alcohol should be diluted between 10 and 15% before being applied to painted surfaces. Isopropyl alcohol is NOT recommended for freshly painted finishes. You should never use isopropyl alcohol at full strength or it could permanently cause damage to your vehicle’s paint.
Isopropyl alcohol, when diluted accordingly, can also be used to prep surfaces for paint, glass or wheel coatings. A common dilution ratio for this is between 10 and 15%.
Here’s an idea of how to dilute this 50% mixture of isopropyl alcohol to a paint-friendly 12.5% mixture: Get a 32 ounce container and pour in 8 ounces, (or ½ of a 16 ounce bottle) of the 50% IPA then fill the container up with water and you get 32 ounces of 12.5% solution.
Using isopropyl alcohol to remove compound or polish residue or for inspecting correction results should only be performed by experienced detailers.
ERASER好像上次某版主发过,异丙醇含量是20~30%?
我一直都是一半一半稀释........
vip8023
它是说 一般稀释比例为10%-15%,新车漆面是不推荐使用IPA的,然后如果太用力的使用IPA有可能导致漆面永久性损坏,但是并没有说用高浓度就会是的漆面损伤。
当然一般肯定需要稀释的,我觉得医用酒精代替如何?
作者说的推荐12.5%的浓度来用,并说不要用在新烤的漆面。
有提到用原液会伤害漆面,并没说其他浓度不ok,所以我觉得1:1还是ok的,有空再查查。
engeman
有提到用原液会伤害漆面,并没说其他浓度不ok ...
1:1使用50%的IPA兑么?如果纯IPA 1:1就是文中所说的50%浓度呀,既然建议稀释到12.5%,估计作者是不建议用50%浓度的,如果是用50%浓度的IPA兑就是25%浓度,但是肯定也是比12.5%的危险性要大了
市面上的大多数油漆以丙烯酸酯为连结料,丙烯酸酯不溶於乙醇,可以溶于酮/酯/苯类有机溶剂。除非连结料以醇酸树脂/酮树脂/聚酮树脂等等特殊用途的油漆,可以使用醇/醚类有机溶剂溶解。
注意!乙醇!不是工业酒精。实际上我的经验是这样:工业酒精用原液的话,漆面会过度地缺失油脂。酒精和水比例不要超过1:1。 50%已经算是很高了。越高越是粘度大!延展性能差。用力过度了会有可能把漆面杀伤
通常漆面抛光后的油脂残余并不是很多,只是非常非常薄的一层,而ipa只需要一丁点就足以去除他们了。所以没有必要太高浓度。太高浓度会把油脂洗掉后,过度地脱掉漆面应有的油脂。其实乳化性的柏油剂都可以去除油脂的喔~
82难
31
医用酒精用过后感觉车漆发白。
AG上IPA用量也非常的少,好像推荐不超过12%。
我目前用的TI,不知道成份,不行先加点蒸馏水
82难
31
89083134 发表于 2013-11-25 14:06
TI有酒精味不? 清水状的吗?
价格还是挺实惠的,要是好用以后就都用这个了~
TI无色无味, 清水状微泡。
不说漆面,就说厨房,地板油了喷两下,一拖,没有油腻感了。
PERL也能轻松干掉。
